Page 20 of 24
FirstFirst ... 10 18 19 20 21 22 ... LastLast
Results 571 to 600 of 710
  1. I tried firefox separately and the result is the same.
    How can I get 5.1 sound? I always get 2ch and Widevine doesn't catch Netflix.
    I need help, thanks.
  2. Originally Posted by mario_2000 View Post
    audio 2.0
    https://s3-dub-ww.cf.dash.row.aiv-cdn.net/dm/3$0ChoIAiBdMAFSBoDAAoHwA3oDgLgXggEBAYgBBBgB/972f/be96/7726/4816-b2e7-3f0db868ab0b/7cc21a50-1019-45d2-8f94-dafac984fd0e_corrected.mpd
    audio 5.1
    always delete this "dm/3$0ChoIAiBdMAFSBoDAAoHwA3oDgLgXggEBAYgBBBgB/" after .net/ in every link.
    netflix isnt working with widevineproxy2. it have some more mechanisms like paramount.
  3. Originally Posted by larley View Post
    No, it should and does work on the latest version of Firefox/Nightly, Chrome and Edge
    your utility is perfect, but i have a little problem is there any python file fragment that can be used
    Bypass HMACs, One-time-tokens and Lic.Wrapping
  4. Originally Posted by larley View Post
    WidevineProxy2
    Hi all, this is the release of my newest creation: WidevineProxy2.
    A browser extension for Chrome/Firefox that intercepts challenges/licenses right after/before EME. Its Widevine implementation is completely JavaScript based (huge thanks to node-widevine), easy to use and works almost any browser-based service.
    The text below is a copy of the README from its GitHub repository:
    Demo
    A demo video can be found here
    Features
    + User-friendly / GUI-based
    + Bypasses one-time tokens, hashes and license wrapping
    + JavaScript native Widevine implementation
    + Supports Widevine Device files
    + Manifest V3 compliant
    Widevine Devices
    This addon requires a Widevine Device file to work, which is not provided by this project.
    + Follow this guide if you want to dump your own device.
    + Ready-to-use Widevine Devices can be found here.
    Compatibility
    + Compatible (tested) browsers: Firefox/Chrome on Windows/Linux.
    + Works with any service that accepts challenges from Android devices on the same endpoint.
    Installation
    + Chrome
    ‎1. Download this repository as a ZIP file
    2. Navigate to `chrome://extensions/`
    3. Enable `Developer mode`
    4. Click `Load unpacked` and the select downloaded file
    + Firefox
    + Persistent installation
    1. Download the XPI file from the releases section
    2. Navigate to `about:addons`
    3. Click the settings icon and choose `Install Add-on From File...`
    4. Select the downloaded file
    + Temporary installation
    2. Navigate to `about:debugging#/runtime/this-firefox`
    3. Click `Load Temporary Add-on...` and select the downloaded file
    Setup
    + Once installed, open the extension, click `Choose File` and select your Widevine Device file.
    + The files are saved in the extension's `chrome.storage.sync` storage and will be synchronized across any browsers into which the user is signed in with their Google account.
    + Due to the sync storage limit of 100KB, the maximum amount of installable of devices at the same time is ~30.
    + Check `Enabled` to activate the message interception and you're done.
    Usage
    All the user has to do is to play a DRM protected video and the decryption keys should appear in the `Keys` group box (if the service is not unsupported, as stated above).
    Keys are saved:
    + Temporarily until the extension is either refreshed manually (if installed temporarily) or a removal of the keys is manually initiated.
    + Permanently in the extension's `chrome.storage.local` storage until manually wiped or exported via the command line.
    Note: The video will not play when the interception is active, as the Widevine CDM library isn't able to decrypt the Android CDM license.
    + Click the `+` button to expand the section to reveal the PSSH and keys.
    Issues
    + DRM playback won't work when the extension is disabled and EME Logger is active. This caused by my fix for dealing with EME Logger interference (solutions are welcome).
    Hope you like it!
    Your utility is perfect, but I have a small problem is there any python code that can be used to bypass to Bypass HMAC, One Time Token and License
  5. Thank you larley
    It's just great
  6. Originally Posted by vitalka View Post
    audio 2.0
    audio 5.1
    Is there also a way to get more video options? It seems that only certain bitrates are offered when using this extension.
    Sep 2005
    Darkest Peru
    I've found a few network streaming sites, Adult Swim and now TNT where this only grabs the first portion of a show and then where there is a commercial break it ends.
    N_m3u8DL-RE "https://vod-media-aka.warnermediacdn.com/tnt/cenc/d8f7f3508869ff6e0da67179a2e7c1cb00000000/master_wv_de.m3u8?playername=top-2.18.0&_fw_ae=ff838de38814328c986fb6640857854f&_fw_ar=1&_fw_us_privacy=1---&_fw_cookie_consent=1&user_ids=Y2RwZmw9bHJmZmYmYWJpcD1uYQ==&guID=&transactionID=17508208647272015309265172" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/137.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://www.tntdrama.com" -H "Referer: https://www.tntdrama.com/" --key ecae72ca069109f7e233ea0400000000:0b9264fbc894a5c9db221c3e5629aa3b -M format=mkv
    What I find is the playlist messes up n_m3u8dl-re. The segments are consecutive wm_6_0_x.mp4.
    When there is a commercial the play list adds:
    #EXT-X-DISCONTINUITY
    #EXT-X-CUE-OUT:0
    #EXT-X-MAP:URI="wm_6_1.mp4"
    Then the segments are wm_6_1_x.mp4. The full video segment playlist is attached to this post for layer6_wv.m3u8 as a text file. The audio is similar as layer7_wv_0.m3u8.
  8. Good evening everyone...
    I state that I have recently arrived in this world and my following question will probably already be answered and I apologize in advance....
    I'm trying to view a broadcast on N0wTV ITA, I can get KID and K and .mpd files of the HD streaming, but the FULL HD version, no!
    I put "Widevine Device" and a linked list file on this forum that allowed me to view the HD source, maybe I have to use a different one from that list to view the FULL HD?
  9. After the last update, from the browser they broadcast 720p at most, so you can't take more, to take 1080p you need a program that emulates a call from a TV or otherwise not from the browser resulting in sending HD manifest and L1 or Playready protection from which to get the decryption key,
  10. Originally Posted by Goku73 View Post
    In the meantime, thank you for the answer!
    Do you know how to show me a software to perform this operation?
    Could a User-Agent go?
  11. Originally Posted by JohnApOphis View Post
    No you need something more complex, that emulates TV, authentication avoiding getting your account banned, channel search, PSSH extraction, token header license, and everything needed to extract the key, possibly through a playready cdm which is easier to find than an L1 widevine, by the way not all playready cdm's work for the purpose, those who have such a program hardly distribute it would be easier to ask if someone would pass you links and channel keys for free, mind you, maybe asking if they contact you privately. That is, if there is someone so kind.
  12. I can see the appeal of 1080p and beyond; especially if you have a large television. But it isn't so terrible to have a smaller TV where 480p looks pretty good. Also it can save you a lot of hard drive space not getting the huge files. I remember as well watching a YouTube review of a new TV that has AI built in that can upgrade the quality up to look and sound even better.
  13. Originally Posted by Goku73 View Post
    Thanks again for the answer...
    Maybe, I found a method but I need help, I notice that from Safari on MacOs it is played in 1080p.... how can I get kid and k from this browser.
  14. Originally Posted by JohnApOphis View Post
    I think Safari uses FairPlay DRM, for which there is no public exploit, it seems. Try Microsoft Edge with PlayReady DRM.
  15. Originally Posted by ytdlhelp View Post
    The streaming doesn't even start with WidevineProxy2 installed on edge.
  16. Originally Posted by JohnApOphis View Post
    You may need to go to edge://flags to enable "Override software rendering list" and disable "Widevine DRM". Then install PlayreadyProxy2 and use a CDM from here.
  17. Well, that's expected. Carefully read again @larley's start post, especially the sentence in bold face letters. Besides that: WidevineProxy2 is about Widevine and not PlayReady DRM. Look at @larley's github projects for PlayReadyProxy2.
  18. I think I gave up, I contacted N0w and they confirmed that on Browser they transmit a maximum of 720P...
    @Goku73's solution for me at the moment is unfeasible without even a help.
    I hope there is someone who can send me the links in private! Although I'd rather get there alone!
    Another alternative would be to find the way with Safari with FairPlay DRM, since they broadcast them at 1080p for which there is no public exploit as @ytdlhelp said
  19. Originally Posted by JohnApOphis View Post
    you have to use a custom script to get anything beyond 1080p for nowtv
  20. Originally Posted by z1269925944 View Post
    If someone could explain to me how to do it for n0w tv ita, I would be very grateful!
    In the meantime, I thank all those who responded...
    At the moment I only found the .mpd of the FULL HD, kid and k are missing.
  21. Originally Posted by JohnApOphis View Post
    If the service is free, and doesn't block all proxies it can find (if having regional restrictions), send the link here so that it can be checked by other people.
  22. Member
    Jun 2025
    Planet Earth
    I have updated the UI Visual elements of the extension
    old:
    [Attachment 87661 - Click to enlarge]
    new:
    [Attachment 87662 - Click to enlarge]
  23. Originally Posted by JohnApOphis View Post
    it's not a free service so unless you are willing to share credentials to let people check, people can't help you
  24. Any way of making this work with an older version of FireFox?
  25. Originally Posted by pesfacemaker View Post
    If you are on Windows 7 they have extended releases of Firefox at least for now.
  26. Originally Posted by Tom Saurus View Post
    I do have the latest available version downloaded and I'm able to install the extension but it's not working. Doesn't give any keys...
  27. Member
    Feb 2006
    what's the name of the website ??
  28. Originally Posted by october262 View Post
    I've tried it on multiple websites and can't get keys from any.
  29. Member
    Feb 2006
    do you have the add-on pinned to the toolbar ??
    and have a wvd file ??
  30. Originally Posted by october262 View Post
    I do.
    I think the extension only works for people on Windows 10 or above that's why I was asking if there was a way it could be made to work on some older versions...
